Great White GW20 w/Flush Mount Interchangeable LED Cartridge Emerald Green The Great White GW20 Underwater Light sets pulses rising, the ultimate predator feared by all. Almost unlimited mounting options thanks to a ultra low profile bezel (4mm) and internal driver system. Thru Hull mounting offers secure fixing with the additional benefit of a removable LED cartridge to eliminate the need for hauling and guaranteed peace of mind. Suitable for transom and side mounting on all hull types. Simple installation thanks to our built-in driver technology, just two wires to connect. Reverse polarity protection with active thermal control, Guard X protective coating prevents marine growth. Specification Suitable for transom and side mounting Surface mount interchangeable requires 101mm/4" entry hole Recommended for boats up to 25M+/105'+ Fixture Lumens 9000 Typical LED life expectancy 50,000 + hours Voltage 24V, Power Draw 7.5A Over voltage, current, reverse polarity, active thermal protection Fixture profile 4mm/0.16" Fixture diameter 140mm/5.5" Fixture Length 170mm/6.69" Lens: optical grade 8mm Boroscilicate glass,65 beam angle Body AB2 Bronze throughout Weight 5.2kg/11.44lbs 2 year warranty
Store | Price |
Walmart US | [show price] |
This item is definitely worth your money,because it costs just 1364.95.It is cheap and you get what you pay for.
